GLOBAL EFFECTS MODULE
  • tosh_tv
    by tosh_tv » Tue Aug 12, 2008 3:53 pm
    Is there any global effects module?
    I cant find any, that works well.
  • Lupin
    by Lupin » Tue Aug 12, 2008 7:30 pm
    no there is no global effect plugin since the software doesn't work with a global pipeline render (i think i'm right)
    if you have a particular effect you wanna apply on every layers you can create a simple module which do this.
    you'll find the information needed to build this module page 105 of the manual
  • tosh_tv
    by tosh_tv » Sat Aug 16, 2008 11:02 am
    Thanks, Lupin! :!:
