CamcamX
  • richardboase
    CamcamX
    by richardboase » Thu Aug 14, 2008 4:36 am
    I bought this briliant little bit of software for feeding a video stream through Skype -only problem is, its quite basic, so I want to run modul8's output through one of its channels.
    In a nutshell - is there a way in which I can ask camcamx to find the preview stream coming from Modul8?
    Because although there IS a live feed from modul8, the only way I could currently do it is to record a movie, render it and then put it in the camcamx as a quicktime.
    But as CamcamX handles webcam inputs, multiple cams and sources - its SO close to be doing this...
    Any bright sparks out there.. give me a clue!!
    Thanks
    = Cyborgs like myself have a tendency to be paranoid about our origins =
  • MrStromberg
    by MrStromberg » Thu Aug 14, 2008 4:30 pm
    if you google for "Stream your desktop as a Video using VLC" you can find another way to stream your modul8 output via internet...
  • MrStromberg
    by MrStromberg » Thu Aug 14, 2008 5:07 pm
    I figured out a silly hardware workaround but if you really need to use the program you could buy a dvi-to-video adapter and loop back in to your computer with a video-to-firewire adapter (http://www.synthetic-ap.com/tips/firewi ... rters.html) You need to find on that will work as an video input device on your computer.
    You could could also buy a dvi-firewire adapter but they are a bit expensive.
    OR you could send the guys at camcamX an email, ask them and not spend any money : )
