motion path module update
    pls
    by pls » Mon Aug 18, 2008 2:36 pm
    motion path module revisited
    i never discovered this module before, but according to the online library it must be there since 2006...
    anyway, when i tested it yesterday i came up with the idea to create a motionblur effect like every compositing software has..
    thanks to yves and his hardcore programming speed variables are already implemented so i just had to do some little mods..
    blurlevel determind by selectspeed [SEL SPD]. creates a motionblur like known from after effects or combustion. type of blur can be choosen in main interface as usual..
    added an extra button to readjust z-rotation [RST.ANG] after using auto angle [AUT.ANG]..
    maybe not the finest programming technics compared to yves.. also the interface could get some more treatment..
    so far.. check out the online library.
    plus loves you
    www.sinsynplus.de
    www.shadovisuals.com
    www.kopffuessler.org
