Modul8 update v.2.5.7
    by ilan » Tue Sep 02, 2008 10:49 pm
    Dear customer,
    Garagecube has released a new update of modul8.
    This update is strongly recommended for all users. The following problems have been addressed with this update:
    - Modul8 slow down due to media changing to direct-to-disk in v.2.5.5 and v.2.5.6.
    - Crashes due to too much memory usage by Modul8 (occurs often on machine with 4GB or more memory).
    Important note for users of Leopard
    Because Mac OS X 10.5 uses more memory then the previous system version it is recommended for users who have less than 4 gigabytes installed to change the preferences under the 'medias' tab. Set the value in the field "Start releasing medias when Modul8 uses more then % of the full memory:" to between 60 or 70%.
    To download the most recent update access the 'Download modul8 Update' command from the 'modul8' menu. If you cannot please contact us at support at garagecube dot com and we will send you a link.
    If you want to use the modules you have downloaded or created using v.2.5.x it will be necessary to move or copy them from the modules folder of that version and put them in the modules folder of v.2.5.7.
    Kind regards,
    The GarageCube Team
  • Frischvergiftung
    by Frischvergiftung » Thu Sep 04, 2008 2:54 pm
    the first field does not have a percentage value, i can only set a mb-value. my computers memory is 1GB, also running leopard, so what should i put in that first field?
    Life is a horrible game, but hey, the framerate rocks!
    by boris » Fri Sep 05, 2008 12:12 am
    The original post we sent today contained an error.The original post is now updated.
    We apologize for the confusion and inconvenience this may have caused.
    by boris » Fri Sep 05, 2008 12:17 am
    60 %
  • Frischvergiftung
    by Frischvergiftung » Fri Sep 05, 2008 10:44 am
    alright now it all makes sense! thanks!
    Ropski
    Re: Modul8 update v.2.5.7
    by Ropski » Wed Sep 10, 2008 6:19 pm
    Dear customer,
    I just got m8 and expierenced quite some crashes, i figured out, it had to do with the memory usage.
    Now all my problems seems to be gone :!: big thanks! i'm happy now :D
  • vincentauxfruits
    Proleme au niveau du flash
    by vincentauxfruits » Wed Nov 19, 2008 2:52 pm
    J'utilise des courts dessins animés en flash et la lecture se fait toujours en boucle, même lorsque le mode de lecture ne l'est pas. Serait ce un bug ? Du coup je suis obligé de rester en 2.5.4 et de ne pas faire la mise à jour de quicktime. Avez vous ce probleme ?
    by sigmasix » Wed Nov 19, 2008 6:09 pm
    par défaut flash boucle sa timeline, si tu mets pas un stop(); a la fin de ta timeline, ca va reprendre depuis le début.
    Si tu mets bien un stop(); dans ta timeline, il y a effectivement un problème...
  • vincentauxfruits
    animation flash
    by vincentauxfruits » Thu Nov 20, 2008 3:50 pm
    le dessin animé que j'utilise a été fait à partir de toon boom et ne fonctionne pas en boucle à priori. Dans la version 2.5.4 de modul8 ça fonctionne parfaitement sans boucle, mais pas dans la 2.5.7 (où ça boucle automatiquement même quand jemets en lecture simple).
    Re: animation flash
    by boris » Sat Dec 06, 2008 12:36 pm
    Bonjour,
    Je vient de voir votre message...
    Pourriez-vous envoyer une description <B>complète</B> du problème...
    Ainsi on aura une chance de le corriger dans la prochaine version.
    N'hésitez pas à joindre un exemple... d'ailleurs quel est le type de media utilisé ?
  • vincentauxfruits
    description du probleme
    by vincentauxfruits » Sat Dec 06, 2008 2:03 pm
    J'utilise des dessins animés créés avec toonboom studio, qui génère un fichier flash swf. Quand j'utilise modul8 v254 avec l'ancienne version de quicktime (celle qui gère encore les fichier flash) mon dessin animé n'est pas en boucle lorsque je l'utilise dans modul8 et que je choisis le mode de lecture linéaire (et pas le mode de lecture en boucle). Dans les versions récentes de modul8 (v257 & v258) la lecture est en boucle de toutes façons ! Je viens de faire un essai intéressant : je viens de lire mon dessin animé avec flash player 9 et il lit de toute façon par defaut l'animation en boucle, peut être que le probleme rencontre dans modul8 vient du fait de l'utilisation de flash player dans modul8. Je ne travaille pas avec Flash directement et du coup je ne peux pas mettre d'ordre actionscript pour dire arrêter la video à la fin et toonboom ne le permet pas non plus.
