help for a newbie pls.
is the matrox dualhead 2 go an option for use on a G4 PPC powerbook?
thanks.
Ok to do what though?
Play one layer, 2, 3, 4, 5,6 .... at what resolution with how many effects?
thanks for advice - however my main question is still - does the dualhead 2 go drain any resources, or is all the work done in the hardware?I find the painter module extremely versatile and useful. I've done whole sets from scratch with it, slowly building up animations through the night. If you stick to it I don't think you'll have any problems with the two screen set up
again, thanks for spending time explaining to an eejit - the max res in my display prefs is 1024 x 768. probably not good enough? though i'm not sure why, if the dualhead2go does the "enlarging" - is it because it doesn't actually improve your resolution - but only "splits" it?its a resolution issue, basically the difference is whether your graphics card is rendering 1024x768 or 2048x768
hi,Dhead2go works by using Vram.
you can see how much you have by using 'about this mac' in the apple menu.
