Global - project wide - perspective transform
  • Vibber
    by Vibber » Fri Sep 05, 2008 12:07 am
    I just recently discovered the perspective transform filter (in the filter module) which is great for lining up the image when my projector is not completely aligned to the screen.
    However - I have to do this for all layers in all layer sets which is tiresome...
    Is there a global module to achieve the same effect? Or something else I can use?
    Best regards
    -Vibeke
    by ilan » Wed Sep 10, 2008 2:58 pm
    At the moment there is no global solution.
    Usually a projector has keystone capabilities that should be able to assist you in these situations.
    deepvisual
    by deepvisual » Fri Sep 12, 2008 4:49 pm
    just duplicate the first layer...
    you can drag the dupes into different sets.
