Problem with .SWF-files
  • miklosion
    by miklosion » Mon Sep 08, 2008 8:23 am
    Hello everyone/anyone! I keep encountering problems with my flash-files...
    I'm using Modul8 2.5.7, and i read somewhere that it uses the flashplugin from Safari. But i can't make my .swf's work. I have published my .swf for flashPlayer 8. And i was thinking, that if Safari can play it, so should Modul8....or???? Makes no sense to me, though. I shall remove my hat shortly in respect, for any clues...
    cheers.
    Miklos
  • Laglotte
    by Laglotte » Mon Sep 08, 2008 4:35 pm
    try to publish with flashplayer 5, that should work
    david
    by david » Tue Sep 09, 2008 1:17 pm
    Hi all,
    normally all Flash media loaded into Safari should work in Modul8. If not please send your information :
    - OS : 10.x.x ?
    - Architecture : PPC vs Intel
    - Flash plugin version : Safari | Help | Installed modules
    - the flash which is not loading
    to support [at]garagecube [dot]com
    Thanks.
    David.
  • movebandit
    by movebandit » Fri Nov 07, 2008 6:52 pm
    ive got the same Problem:
    No Flash file is playing. I can open all of them in Safari. Tried several ones in different Versions from Flash Player 4 till 9 / Actionscript 1 and 2. Stopped all modules in M8.
    No Preview in Media
    Shockwave Flash 10.0 r12
    Systemversion: Mac OS X 10.5.5 (9F33)
    Kernel-Version: Darwin 9.5.0
    Modellname: MacBook Pro
    Modell-Identifizierung: MacBookPro4,1
    Prozessortyp: Intel Core 2 Duo
    Prozessorgeschwindigkeit: 2.5 GHz
    Anzahl der Prozessoren: 1
    Gesamtzahl der Kerne: 2
    L2-Cache: 6 MB
    Speicher: 4 GB
    Busgeschwindigkeit: 800 MHz
    Boot-ROM-Version: MBP41.00C1.B03
    SMC Version: 1.28f1
    david
    by david » Fri Nov 07, 2008 7:06 pm
    Hi all,
    Modul8 2.5.7 does not work with Flash 10, so for the moment, stick to Flash 9.
    Modul8 2.5.8 will solve this problem.
    Users who want a beta version of 2.5.8, please contact support [at] garagecube [dot] com
    David.
  • movebandit
    by movebandit » Thu Nov 13, 2008 12:07 am
    Yes, Solution: Downgrading the Safari Flash Plugin to 9.0 r47 solved the problem.
    Thanks
