Multiprojection without G5 or matrox cards + scripting refer
  • FrankChendra
    by FrankChendra » Fri Sep 12, 2008 4:25 pm
    i have gotten the job to make a 5 screen installation (multiprojection) work with Modul8.
    The drawback is that I do not have a G5 with multiple graphic cards, nor any matrox card. Instead, I got a Mac Book Pro and 4 Mini Macs, wired by a wifi setup. Each machine will address one video beamer.
    The 5 screens to synch will not be close together, but in some distance to each other, which is why we opted for a networked synch setup instead.
    I found the network module in the plugin directory, and I can control the second machine from the first one.
    Yet i am desperately seeking any reference for the scripting used in the Modul8 extensions (modules). I know it is Python (which I know), but I don´t know which objects are there, how to adress them, etc.
    Any help would be much appreciated.
    Thank you very much,
    Frank Chendra
    deepvisual
    by deepvisual » Fri Sep 12, 2008 4:48 pm
    I no little about networks, but you could control all 5 via MIDI if you get nowhere with the other method
  • videomasta
    by videomasta » Fri Sep 12, 2008 7:58 pm
    hello, there is no documentation, accept the doc pdf.
    this is full of errors and uncompleted.
    it is very sad, but this is everything we get from the modul8 team :-(
    i would recomment you to have a look at the
    OSC (GLOBAL) module.
    with this module as a base, you should be able to synchonise
    your machines.
    if you have problems, feel free to ask the forum :-)
    good luck !
