mowgli_uk wrote:and although its been mentioned before multiple midi setting easily available
anomad wrote:. if i could block the channel 1 data, it would save me a lot of time building my setups!
david wrote:
Next major release will let you enable/disable some devices but for filtering out some channels you will have to use a MIDI router.
david wrote:Do you have example of application allowing you to choose which channel you accept/ignore ?
