automatically switching clips based on bpm
  • aletheia
    by aletheia » Mon Sep 15, 2008 3:12 am
    hey :)
    so here's what i want to do:
    my partner is using ableton live 7 and i am using modul8 v2. i want to switch between clips based on the bpm that my partner is using, so that, say, when every 4th kick plays, my clip will dissolve into the next clip and play until the next kick sounds, and so on.
    how can i do this in modul8? how do i go about setting things up?
    thanks so much for any help!
    ps. i searched on the forums and still couldn't figure things out... if i missed something, let me know. thx.
    Lo
    by Lo » Wed Sep 17, 2008 11:40 pm
    Try to use the Layer Sequencer module :wink:
    PAUSE
  • mowgli_uk
    by mowgli_uk » Thu Sep 18, 2008 11:56 am
    or the slideshow bpm but I doubt that any of this will work with version2
    Lo
    by Lo » Thu Sep 18, 2008 7:36 pm
    I can't find any slide show module based on bpm :?
    but if you can tell me what is his name I'm very interested :)
  • mowgli_uk
    by mowgli_uk » Fri Sep 19, 2008 10:13 pm
    you need to upgrade your version of modul8....................why version 2?
    Lo
    by Lo » Sat Sep 20, 2008 1:12 am
    but I have the last upgrade of modul8,
    I can find two slidshow module:
    the GC slide show (layer)
    and the (vs) media sequencer
    none of them is abble to run at the BPM rate :(
    or is there somthing I don't understand :?
    by vanakaru » Sat Sep 20, 2008 10:25 am
    I wonder if SlideShow BTM is not working with new v. any more. It is not in public library any more as well.
    When I run it it creates errors!?
  • mowgli_uk
    by mowgli_uk » Sat Sep 20, 2008 11:47 am
    I've just uploaded it to the public library
    by vanakaru » Sat Sep 20, 2008 11:33 pm
    it seems not working. as soon I activate *watch BTM* it freeze, but next/prev buttons still work.
    It would be nice to get this working. otherwise I must use the version of M8 where it still was OK.
  • mowgli_uk
    by mowgli_uk » Sun Sep 21, 2008 12:58 pm
    Mine works fine. Have you got the global BPM set to 0 by any chance? I'm using the (VS) version of the global bpm by the way.
    by vanakaru » Sun Sep 21, 2008 3:29 pm
    first I run it without global BPM. I try with it set 120 and 0. result is the same
