how do i authorize?
  • queglay
    how do i authorize?
    by queglay » Mon Sep 15, 2008 3:57 am
    i just purchased modul8 however it doesn't ask me for my auth code when i start it up. when i click "update my reg info" that all works, but i still can't save files.
    is there anything i can do to reset the authorization status and defaults?
    thanks for any help.
    david
    by david » Mon Sep 15, 2008 8:42 am
    Hello queglay,
    are you using the demo version ? What does the "License to :" field of the About dialog (Modul8 | About Modul8...) says ?
    David.
  • queglay
    by queglay » Mon Sep 15, 2008 10:06 am
    under licensed to is blank. im using the full version of 2.5.7
    I'll admit that i tried a cracked version for a few days before i just bought the full version yesterday.
    by vanakaru » Mon Sep 15, 2008 6:55 pm
    You may want to find all M8 related files and remove them before running and serializing you new version again. And do you activate over the internet?
    david
    by david » Mon Sep 15, 2008 7:10 pm
    Hi all,
    In this case, the solution was to deauthorize Modul8 (this will invalidate the cracked serial) and then go through the normal authorization procedure (online or offline).
    David.
