I just wanted to check what maximum preload mem size you guys usually set and your other ram settings should be set to if you have 4gb of ram.
its all a bit new to me and its hard to determine whats optimal.
On Leopard, the "Start releasing media" should be 60%-70% to leave room for other app to run otherwise OSX will begin to swap/paginate (transfering part of memory to/from disk).I just wanted to check what maximum preload mem size you guys usually set and your other ram settings should be set to if you have 4gb of ram.
