BPM Router
  • Movement
    BPM Router
    by Movement » Fri Sep 19, 2008 1:48 pm
    Hi
    Can you use the BPM router module to determine the speed of a clip, keeping the original in and out points and keeping the speed constant?
    I basically want to be able to tap or synch the BPM and for Modul8 to determine how fast the clip needs to play to synch with the desired BPM.
    I've been having a play and can get it to do everything with clip speed other than what I want....
    Lo
    by Lo » Sat Sep 20, 2008 12:55 am
    You've just to pick one of the two scrath knobs of your layer (under the speed slider) with the BPM router.
    Your loop will run at the BPM rate :wink:
  • Movement
    by Movement » Tue Sep 23, 2008 12:29 am
    Cheers Lo. Exactly what I was after
