slow color picker
  • good ?
    my gran'ma' can do better
    0
    No votes
    well, not bad
    1
    100%
    gooooood
    0
    No votes
    Total votes: 1
    zoophar
    slow color picker
    by zoophar » Tue Sep 30, 2008 2:06 pm
    A new little module to change progressively the additive color of a layer.
    the color are choosen via the prefs pannel:
    1) select color picker to open 'appleColorPicker' and choose a color
    2)assign the color obtained in the colorPicker by pressing the button c(number)
    3)once all the colors are chosen, press ok and play with additive color
    4) values are saved via moduledict() (thx vionSonore for the tuotorials: http://modul8.visionsonore.net/)
    so when you quit M8 and restart,the colors are saved
    (but only when it is choosen in the play mode :cry:)
    5)the knob let you change the time it takes to change color
    please feedback to get to the 1.00 version: modul8@zoophar.com
    ENJOY !!!!!
    Lo
    by Lo » Wed Oct 01, 2008 12:51 am
    Hi
    A new interesting module :)
    you should give the choice of additive or modulate color :wink:
    zoophar
    by zoophar » Wed Oct 01, 2008 9:40 am
    1) Yes, of course, both add and modulate at the same time either, the choice should be given
    2) What about either, a third button that would:
    a)activate luma key
    b)set progressivelly the modulate color to 0 while the additive color is beeing modified
    3) I was also thinking to have the possibility to change the 10 layers a the same time but i have to recuperate the RGB value of all the layer
    (cause if not, it cuts to the color of the active layer and then, changes progressivelly.)
    Thx for the feedback LO
Users browsing this forum: No registered users and 46 guests
