Elgato EyeTV 200
  • returntrip
    Elgato EyeTV 200
    by returntrip » Tue Oct 07, 2008 3:48 am
    Any chance I can get this to work as an input w/ Modul8? It shows up as a device, but it isn't selectable, titled "IIDC FireWire Video". Any help would be appreciated.
    deepvisual
    by deepvisual » Tue Oct 07, 2008 12:11 pm
    this should work
    go into quicktime preferences and select the video camera then go back to modul8 preferences
  • returntrip
    by returntrip » Tue Oct 07, 2008 7:00 pm
    I did that just now, and Quicktime doesn't recognize it at all. It only recognized my iSight. I'm going to poke around Elgato's site and see if I can find some drivers or some updates I don't have. Thanks.
    deepvisual
    by deepvisual » Wed Oct 08, 2008 9:08 pm
    it could be something as simple as having it set to digital out instead of digital in...
    but if QT can't see it modul8 can't either..
    david
    by david » Fri Oct 17, 2008 5:14 pm
    Hello returntrip,
    I received my Elgato EyeTV TNT and it could not be used as a "video capture" device because Elgato is not providing a QuickTime vdig (video digitizer) driver.
    Elgato is providing an SDK to get the video stream out of the EyeTV software. But we will have to write a EyeTV plugin + a vdig component for QuickTime.
    If you want to capture TV inside Modul8, you will have to choose a video capture card that provides a vdig QuickTime component.
    Best regards.
    David.
  • videsad
    DCAM / IIDC FireWire Video
    by videsad » Wed Feb 03, 2010 1:49 pm
    I Think you have to buy a Firewire Cam like this one:
    http://www.theimagingsource.com/de_DE/t ... zAodWD01cA
    i think it should work so.
    Greets videsad
  • rafidean
    by rafidean » Fri Sep 03, 2010 5:52 pm
    argh! i should have read this before going out to buy the only Mac compatible video capture device I could find!
    this Elgato Video Capture dongle is now useless for me, tried everything and it just doesn't work. The only workaround is to use the v002 Screen Capture quartz composer plugin. But even that doesn't show up in Modul8. It does work in VDMX. I might have to install an additonal plugin to make it work.
    damn. now to offload this Elgato and get a proper one.
    Does the Blackmagic Design Video Recorder work? http://www.blackmagic-design.com/produc ... orecorder/
    david
    by david » Fri Sep 03, 2010 6:19 pm
    rafidean wrote:Does the Blackmagic Design Video Recorder work? http://www.blackmagic-design.com/produc ... orecorder/
    The short answer is NO
    The less shorter is that Modul8 only handle capture device that have a quicktime VDIG driver.
    Regards.
    David
  • rafidean
    by rafidean » Fri Sep 03, 2010 6:34 pm
    thanks for the speedy reply, David.
    hmm.. i guess i'll have to go for the Videoglide option. the problem is, these things are really hard to get here!
