midi control - cc, sysex, rpn, nprn
  • gviz
    by gviz » Tue Oct 07, 2008 3:08 pm
    ivw just bought myself a novation zero sl (maybe a mistake as it seems far too complex) and i'm trying to map it for modul8 ive been trying for a couple of days and strugling. what command code should i be using and does anyone have any advice or guide to mapping or even a tempalate.
    cheers
    gviz :?
    g4jon
    try this
    by g4jon » Sat Oct 18, 2008 1:49 pm
    hello
    try using this to make and upload your own template to the remoteSL,
    ReMOTE ZeRO SL Template Editor 1.1
    http://www.novationmusic.com/support/so ... e_zero_sl/
    You can name all the controls on the device, so they match whatever you assign to them, ie. Layer1 M8 to Slider 1 on RemoteSL. etc
    I have a basic template I can email to you, you can then edit it as you please.
    plax
    by plax » Mon Mar 09, 2009 12:20 am
    try to make my own template for Modul8 with my remote 25 SL compact but dont know how work the template editor, can't understand what are cc, sysex, rpn, nprn could domeone post a template for the 25 SL compact or try to explain what can i do ?
    macbook intelcore duo 2 GHZ - 2 giga de ram
