midi controller
  • neo
    midi controller
    by neo » Fri Oct 10, 2008 10:59 am
    Hi
    should I buy a midi controller for modul8 I can recommend some products that are compatible? I would give a friend a Numark NuVj is fully compatible?
    Thank
    neo
    deepvisual
    by deepvisual » Sat Oct 11, 2008 2:21 pm
    novation zero sl looks very good.
  • neo
    by neo » Sat Oct 11, 2008 3:38 pm
    thank you, very interesting you use it with modul8? is 100% compatible? is easy to configure?
    neo
    g4jon
    ReMOTE ZeRO SL
    by g4jon » Sat Oct 11, 2008 4:33 pm
    I have one of these, its very good. Its easy to set up use the ReMOTE ZeRO SL Template Editor 1.1 from this link:
    http://www.novationmusic.com/support/so ... e_zero_sl/
    It has 8 sliders, I assign 6 of them to layer opacity (3 on bus A & 3 on bus B) and use the remaining 2 sliders for other functions.
    There are cheaper controllers with more dials etc but you get what you pay for. Why not go to digital village and try a few, see what you like best.
  • neo
    by neo » Sun Oct 12, 2008 3:03 pm
    Thanks for your interest and your valuable information.
    neo
