sound in!!
  • locarmen
    sound in!!
    by locarmen » Sat Oct 11, 2008 11:11 am
    I have a problem with soound in when i try to applay it to an animationFX just like "auto move - auto scale". I put the "sound level in" in its middle possition but doesn´t respond well. I have in my computer selected the internal microphe to make these effects act but it doesn´t.
    Which one could be the problem?
    Thanks a lot
    javier
    deepvisual
    by deepvisual » Sat Oct 11, 2008 2:20 pm
    turn the sound in up full.
    by vanakaru » Sat Oct 11, 2008 5:00 pm
    look at your mic input level as well.
    david
    Re: sound in!!
    by david » Sun Oct 12, 2008 10:09 am
    You must first adjust the sound level from the System preferences.
    System Preferences | Sound | Input
    select the input device and adjust the level until you see something moving in the level bar.
    The Sound in level in Modul8 does not change this level, so you must first set the sound level in the Preferences.
    David.
