Sequencer
    VJ-A2D
    Sequencer
    by VJ-A2D » Fri Jun 10, 2005 5:28 pm
    Hey,
    Would it be possible to build a sequencer for Modul8 with the modul editor? I haven't looked completely in details about what can be done exactly.
    Also, is it possible to add a DVD source to Modul8, if not is it possible to create a module for that , so it would be possible to use DVD's and mix over it ;)
    VJ A2D group
    lego_man
    by lego_man » Fri Jun 10, 2005 6:11 pm
    it sould be very nice to have sequencer in M8
  • Guest
    Re: Sequencer
    by Guest » Mon Jun 27, 2005 11:20 am
    that'd be great! but probably consume a lot of processor power?
    VJ-A2D
    by VJ-A2D » Mon Jun 27, 2005 7:00 pm
    No i wouldn't think so .. not more than the DV camera capture .. Need to test it
    Plus2 Collectiv
  • kolis
    by kolis » Fri Nov 11, 2005 10:38 pm
    Ohh yes, DVD source support would be sweat.
  • moonbase
    by moonbase » Sat Nov 12, 2005 1:22 am
    Portable DVD player plus mixer work well for me. Also gives you a monitor screen when not using the DVD.
    Am I missing something? What benefit would there be in putting all this through the laptop?
    Logical Record works as a crazy sort of non-visual sequencer.
    Something more memorable and visual and save-able would be really excellent though.
    Hmm, can you save a logical Record 'set' as something other than a render?
    Will have to check, don't think so.
