Kenton Control Freak 16ch
    g4jon
    by g4jon » Sat Oct 18, 2008 1:16 pm
    Hello All
    I am trying to use the CF SE EditorX v1.0 to make a program name/assign the control freak. I can't seem to get it to work.
    If I try to map the device in M8 using say a predefined program, say "P2 controllers 1-16" M8 will take and map the midi message from slider 1 to layer 1, slider 2 to layer 2 and so on. BUT if I then try to map button 1 on the freak to layer 1 on/off on M8, it is not seen by M8.
    I also use a remote Zero SL, that I want to use as well, I have no problem using the editor for this.
    Any help, Ideas on best configuration greatly appreciated.
    using control freak into m-audio midisport 2 anniversary edition.
    thanks
    I
