Which MIDI Controller for Modul8
  • bright!
    by bright! » Mon Oct 27, 2008 11:28 pm
    Hi there
    i am quite new to Modul8 and i was wondering, which external Midi Controller / Faderboard would be nice to use with Modul8. Any good or bad experiences on a usefull layout for one or the other MIDI Controller? Which ones are you guys using
    Thanks for any input
    Thomas
    by vanakaru » Tue Oct 28, 2008 1:51 pm
    2-3 iPod Touches and iTouchMidi Matrix, Tilt, Pad.
    Custom made scrtch pad. (modded simple USB MIDI controller)
    BTW this question is asked every other month, so do search too.
    wygiwys
    by wygiwys » Sun Nov 02, 2008 1:57 pm
    The Akai MPD-24, it's not that expensive, and it has got some good controllers.
    And the super midi controller is the Codanova VMX, a lot of knobs, pads, and jogging wheels.
    What You Get Is What You See
    WYGIWYS.tv
  • anomad
    by anomad » Sun Nov 02, 2008 11:05 pm
    . i primarily use a livid instruments Ohm controller then combinations of Evolution UC-33e, Korg padKontorl and Edirol Oxygen8 -- depending on the project
    . one day, i'll link them all in at the same time >:)
  • garageRoot
    by garageRoot » Wed Nov 05, 2008 2:15 pm
    I have been using the M-Audio Trigger Finger for longest with modul8. Cheap, light and can handle a decent amount of abuse. This is especially useful if a lot of the performance involves triggering of layers and actions built with modules.
    Have had access to the MPD-24. It is a decent runner up for the TF but it does not work out of the box with m8 the way the TF does.
  • Ghostvisuals
    by Ghostvisuals » Thu Nov 06, 2008 1:35 am
    Hi if your looking for good fun Midi controller ? i use a Lemur. Its great.
    by ilan » Fri Nov 14, 2008 4:27 pm
    Lemur controller is an OSC based controller. :wink:
  • mowgli_uk
    by mowgli_uk » Fri Nov 28, 2008 1:24 pm
    and expensive...
