ctrl_layerStack_focusPosition and basic questions
  • quote
    by quote » Fri Nov 07, 2008 2:26 pm
    hiho,
    i want to start making my own modul in which i control the focused Layer..
    i started with a button and assigned in script connect a send message (goToThree)
    in the script window i wrote under messageEvent:
    Code: Select all
    if msg == 'goToThree' : modul8.setValue('ctrl_layerStack_focusPosition',3)
    but somehow i'm making something wrong. cause there is no reaction in modul8 if i press the button..
    is there somewhere a homepage where i can look up the commands (besides the keyword browser)?
    what am i making wrong in my basic module?
    please don't be upset if this is a commom question but i just didn't find something on the internet which explained it to me :)
    greetings david
    Lo
    by Lo » Sat Nov 08, 2008 3:22 am
    I can't help you for the script ( except to advise you of being sure of restart your layer after you've wrote the script )
    But here I have an easier solution
  • quote
    by quote » Sat Nov 08, 2008 2:17 pm
    ok.. it's working so far. i used "ctrl_layerStack_focusPosition"
    is it possible to use a variable in the expression field?
    for example
    Code: Select all
    value = newValueUP
    and the variable newValueUP contains the old active layer minus one.. so that i can switch through the layers?
    i didn't found the things i wrote in the keyword connect tab in the script tab..
    hope that i made my point clear :)
