sequence of clips
  • frenzis
    sequence of clips
    by frenzis » Tue Nov 11, 2008 6:04 pm
    hallo to everybody. I'm a new modul8 user.
    I have modul8 2.01
    Maybe someone could help me.
    I need to play some clips in sequence, from the beginning to the end of each clip and switch to the following at its beninnig, and so on.
    how can I automate that?
    the following clip must obviously start from the beginnig.how can I be sure of that (I can not use loop)?
    is there a way to see a timeline with the playhead of each clip (this could be useful if I can not automate the action of switching)..
    thank you, I looked around the forum but I did not find an answer for me..
    f
    by sigmasix » Tue Nov 11, 2008 6:05 pm
    can you upgrade your modul8 version?
    then there is a module called slideshow that will do the job! latest modul8 version: 2.5.7
  • frenzis
    sequence of clips
    by frenzis » Tue Nov 11, 2008 6:11 pm
    thanks but unfortunately I have a mac OS X 10.3.9 so I can't. Is there any other way to do that?
    by vanakaru » Tue Nov 11, 2008 11:04 pm
    Maybe you can white your own Slideshow module. Or upgrade OS X Tiger is better than Panther in some system usage. If your mac will not run smooth Tiger or Leo, then your slideshow would probably run poorly as well.
    Or create your sequence in Quicktime or MpegStreamclip.
    I has been long time since 2.01.
