Midi mapping changes in v 2.5.7?
  • deckard97
    by deckard97 » Wed Nov 12, 2008 12:04 pm
    I want to know how or what changes have been made since v 2.5.4 because I'm having a problem with a MIDI interface controling Modul8 in v 2.5.7.
    With a custom MIDI interface I control a few interface elements, one of which is the direction of playback in the "PLAY" section of the layers panel.
    in v 2.5.4 we used to send a command that would result in the direction "forward" and another command that would result in the direction "reverse".
    in v 2.5.7 the same commands seem now to toggle between directions wether we send "forward" or "reverse".
    For example, if I send the command "forward", then "forward" again, the result is "reverse" whereas in v 2.5.4 the result was "forward"...
    I'm attaching an e-mail from the programmer about the source code of the custom MIDI interface, I would really like to understand the changes in v 2.5.7 so that we either could burn another chip to get our interface behavior back or something.
    Selon le source code que j'ai ici le bouton a trois états :
    Fwd, Still et Rev
    Les commandes qui sont envoyées dans chaque état sont les suivantes :
    Fwd : CC#24 = 127 // Opacity = 100%
    CC#14 = 0 // Send direction = FWD
    CC#23 = SPEED // Send speed
    Still : CC#23 = 0 // Speed = MINIMUM
    CC#24 = 50 // Opacity = 50%
    Rev : CC#24 = 127 // Opacity = 100%
    CC#14 = 100 // Send direction = REV
    CC#23 = 127 // Send speed = MAX
    La routine est la suivante :
    Est-ce que Still est enfoncé?
    Oui, était-il déjà enfoncé?
    Oui, do nothing...
    Non, alors envoie la commande Still
    Non, Est-ce que Fwd est enfoncé ?
    Oui, Était-il déjà enfoncé ?
    Oui, do nothing ...
    Non, alors envoie la commande Fwd
    Non, Est-ce que Rev est enfoncé ?
    Oui, était-il déjà enfoncé ?
    Oui, do nothing ...
    Non, alors envoie la commande Rev
    Non, Loop from the top
    by boris » Tue Dec 02, 2008 11:58 pm
    Hum my apologies I missed your message...
    Nothing are supposed changes from the version 2.5.4
    Is your problem resolved ?
    Let me know...
    Best Regards.
Users browsing this forum: Google [Bot] and 17 guests
