Using Modul8 UI on another display and Output through Svid?
  • Grovenstien
    by Grovenstien » Fri Nov 14, 2008 11:28 pm
    I am a long time lover of modul8! I have used this fantastic piece of software for about 5 years now! Surpasing others such as Livid Union and the rather plain Arkaos!
    Modul8 being so intutive i have never really needed to use this forum! But now i have a question. This may seem obvious to some but i just cant figure out how to put the user interface onto another monitor.
    I am using a G4 power book with DVI (Through to VGA) out to a second monitor and SVID through an MX50 and to the show!
    Some modules will freely float around onto any display you wish to put them but the main UI is locked to the lappies display?
    I have resently built a multi touch table ( for info on Homebrew MT technologies checkout NUIgroup or google touchlib ) and want to use it for live gigs using my much loved modul8.
    Any way thanks for all the fantastic VJ stuff i have been able to do with this, the pinnacle of video performance software!
    8)
    david
    by david » Sat Nov 15, 2008 10:46 am
    Hello Grovenstein,
    the main UI of Modul8 goes on the screen where the dock/menu bar are (main screen).
    You could change which of your display is the main screen :
    System Preferences | Displays | Arrangment | relocate the menu bar by dragging it
    At the moment, this is the only way to get Modul8 UI on another physical screen.
    David
  • Grovenstien
    by Grovenstien » Sat Nov 15, 2008 3:45 pm
    Thanks David i will try this.
