lego_man wrote:apparament il y a une erreur de script sur ce module... ou aolrs c'est parce que je l'ai installé sur la beta 4... (j'attend toujours le mail pour la version 2:wink: ) mais en tout cas j'ai eu un gros message d'erreur quand je l'ai installé
sigma6 wrote:coolgreat job!
For the text module, you can set on and off but if you have a media on your layer and you click on, the media is replaced with time and if you reclick on the button (off in this case) the time stops but you don't get your media back
sigma6 wrote:hum... I don't know how you made the new bpm module but if you check and uncheck the rotation and zoom boxes the rotation or zoom value don't go back to default, and we're unable to change these values, I mean the rotation knob is to 0 and the layer stills rotated... we're forced to pause and play the module to go back to default values....
Mandingo wrote:These new modules are great. I really like the random frame. Would it be possible to add a button that would trigger a random frame jump when you hit it with the random speed all the way down. I tried but am just not very good at coding.
