Midi "NOTE OFF" interpretation
    zoophar
    by zoophar » Thu Nov 27, 2008 10:15 am
    Hello there,
    trying to do thing with MIDI and M8
    but can't have a NOTE OFF signal... in M8
    tried with pure data / then a MIDI hardware by Roland /
    >while the midi Monitor.app shows me NOTE OFF
    >M8 sees it as param['param2'] =0
    How can i make M8 see the REAL: NOTE OFF msg to set a button OFF
    (and not from the param['param2'])... beacause it's not the way we use to do it...
    CHEERZ
    zoophar
    by zoophar » Tue Dec 02, 2008 10:45 am
    Hello myself how do i do?
    It's like that...
    it's the second way of sending NOTE OFF:
    NOTE ON message with velocity 0
    this method is legal by the MIDI specification....
    have a nice day myself....
  • markvomton
    I have the same problem
    by markvomton » Wed Apr 01, 2009 5:22 pm
    Hello, i want to try Layer on/off via midi,(ableton live7) but i can not send midi note on with velocity 0.
    How it is possible to make a layer off?
    zoophar
    by zoophar » Wed Apr 01, 2009 7:31 pm
    hello markvomton ;-)
    this is a note concerning how some applications understands midi NOTE OFF..
    I think you could just send a normal NOTE OFF from Ableton,
    and see how it is understood in M8: you should see param['param2']=0 (this is the velocity)
    if you are mapping midi via the interface (menu map midi keys) you shouldn't care about anything.... m8 just takes all in charge...
    1)in M8: just select the knob you want to map,
    2)in Ableton: send your midi signal.. NoteOff and NoteOn are automatically handled... and you shoud see the channel/note written on the knob in M8...
    hope i was understandable,
    if not, just say it i will try another way to explain
    PS: Have fun ;-)
    david
    by david » Fri Apr 03, 2009 12:28 pm
    Hello Zoophar,
    It's like that...
    Modul8 is receiving the NOTE OFF midi message
    A module that do (in DirectEvent) :
    print type, param;
    gives
    MIDI {'timestamp': 14513855337059.0, 'channel': 1, 'param1': 2, 'message': 'NOTE_ON', 'rawEvent': 144, 'param2': 64}
    MIDI {'timestamp': 14514003451505.0, 'channel': 1, 'param1': 2, 'message': 'NOTE_OFF', 'rawEvent': 128, 'param2': 64}
    So you should be able to write a Module to handle this toggling issue (not supported by current MIDI mapping).
    Best regards
    zoophar
    by zoophar » Fri Apr 03, 2009 7:58 pm
    thank you David,
    for me it was ok since i answered to myself...
    i wrote this because i discover (googling) it was legal to have a noteOff that is understood like: "noteOn with velocity=0"
    it's maybe the device (or app) that sends the message that way,
    (like french and suisse-romand: ex: 90 == nonante or quatre-vingt-dix... but's its the same...it just depends your sleng...)
    in my case: Modul8 recieves messages from PureData...
    i am now writing a module to monitor the midi signals:
    ':arrow:' see the incoming midi signals in a "view window"
    a rect for each note in an XY table...
    ':arrow:'send some of the sgnals trougth sharedDict() (send the "mapped" notes, the wanted ones, they appear in a different color...)
    (little Prob: dont' know how to clear the sharedDict() )
    ':arrow:' another piece of module
    (more a brick of module to do wat you want...)
    Get the selectionned sharedDict()message...
    (selection is made trough a list of all the sharedDict() keys)
    it could be something like a "esaySharedDict()" thing. to copy-paste in a module with a real function...
    still in beat version,
    if some of you want to test it or are interested, just drop an email ;-) and let's go !!!
    just send some feedback please
