Vendo AKAI MPD24
  • christ__
    MPD24
    by christ__ » Fri Nov 28, 2008 6:59 pm
    christ.photos@gmail.com
    La use en casa algunas veces para configurarla y probarla, pero por el momento no la estoy usando y necesito juntar plata para otro chiche.
    Incluye manuales, cds, cables, etc.
    El estado es igual a nuevo sin detalles de ningun tipo.
    Precio: 290 dolares
    * 16 velocity and pressure-sensitive, genuine MPC pads
    * 4 selectable pad banks for a total of 64 pads
    * 6 assignable Faders for transmitting MIDI Control Change data
    * 8 assignable 360? knobs
    * REW , FF, STOP PLAY and REC buttons that transmit MMC (MIDI Machine Control) messages to DAW/Sequencing applications
    * Backlit, easy to read LCD display
    * MIDI and/or USB operation
    * USB powered (or powered via optional AC adaptor)
    * Included Editor Librarian software (Mac and PC )
    * MPC 16 Level and Full Level feature
    * Includes a customized version of Fxpansion's BFD Lite
    Minimum System Requirements (Platform, OS, RAM)
    * Mac OS X 10.3, Windows XT
    Computer Interface (USB, FireWire, Serial, etc.)
    * USB/MIDI
    Displays
    * custom LCD
    Number of Faders
    * 6
    Number of Knobs
    * 8
    Number of Footpedal Inputs
    * 0
    Number of Software Assignable Switches
    * 0
    Sends Sysex Strings (yes/no)
    * no
    Transport Controls (yes/no)
    * yes
    Track Switches (including select, mute, solo)
    * no
    Automation Type (MIDI, Internal, Both, or None)
    * none
    PAD CONTROL REDEFINED.
    Akai Professional?s MPD 24 is the velocity sensitive pad controller for musicians
    and DJs. Modeled after the landmark MPC series, the MPD24 allows for
    an extremely expressive and intuitive solution to percussion and rhythm
    programming.
    With 16 MPC-style velocity and pressure sensitive pads, four selectable pad
    banks for a total of 64 playable pads, six assignable faders and eight assignable,
    360? knobs for transmitting MIDI Control Change data, the MPD 24 provides
    unprecedented creative freedom for manipulating sampled material. The
    MPD24 also features transport controls for interfacing with DAW/sequencing
    applications. The MPD24 is a fully programmable controller and multifunctional
    tool that fits perfectly within any production or performance environment.
    "La rebelión consiste en mirar una rosa hasta pulverizarse los ojos"
Users browsing this forum: Baidu [Spider] and 4 guests
