How can i sync MOV. to Audio Files in Modul 8???
  • M.150
    by M.150 » Mon Dec 01, 2008 10:15 pm
    Hi Folks....okay, i try to find out, the thing with audio - sync in modul8. (sorry...my englisch is not so gooood.) so i must work hard to read the hole manual. but one thing i dont understand...how can i sync external audiofiles, like wave, aiff, mp3 or whatever in modul 8 to my MOV. files. i worked before on PC ( resolume) and in that programm i could sync my audio to FFT (Fast Fourier Transformation) analysis.
    Can Modul 8 this like resolume, or is there a diffrent way?
    THX a LOT.... :)
  • incuf
    by incuf » Fri Dec 05, 2008 6:12 pm
    with the MOVIE TIME (layer) module you can do it.
    You can make that audio affects the movie speed, or frame position. It also has a Random frame option
    cheers
    myspace.com/eyeburner
  • M.150
    by M.150 » Fri Dec 05, 2008 7:21 pm
    Hello!!
    Thank you!! But i dont find any link where can i buy this modul....
    i found out somthing diffrent ...i hope im right...when i connect my hardware synthesizer setup with my Imac input, and i use in the master panel IN, an take bpm master modul...i think then it is in sync right?
  • incuf
    by incuf » Fri Dec 05, 2008 7:25 pm
    go to "modules" menu in modul8 and select "Online Library..."
    then select tho module from the list and click install
    cheers!
    incuf
  • M.150
    by M.150 » Fri Dec 05, 2008 8:52 pm
    ok....thank you.... :wink:
