Modul8 update v.2.5.8
    by ilan » Fri Dec 05, 2008 1:36 pm
    [EN] Modul8 version 2.5.8 update
    Dear customer,
    An update to modul8 has been uploaded to our servers today. The update adds some modifications to existing features and resolves some conflicts that have emerged with the recent updates to Mac OS X.
    What's new:
    - Support for .swf file playback using Flash 10.
    - Support for video capture (live video feed) at HD resolution.
    - Default memory settings in the preferences are now set to 60MB, 60%, 128MB.
    - Default video capture settings are now at the maximum quality.
    Fixes:
    - Potential crashes when changing media quickly.
    - Potential freezes during a logical render.
    - In Leopard the output window did not return to front when switching to modul8 from another application.
    - Possible crashing when detecting video cards.
    To download the most recent update access the 'Download modul8 Update' command from the 'modul8' menu. If you cannot please contact us at support at garagecube dot com and we will send you a link.
    If you want to use the modules you have downloaded or created using v.2.5.x it will be necessary to move or copy them from the modules folder of that version and put them in the modules folder of v.2.5.8.
    Kind regards,
    The GarageCube Team
  • PRICKIMAGE
    by PRICKIMAGE » Wed Dec 10, 2008 7:29 pm
    hey
    looking fwd to using new version
    since installing on both my machines and deleting previous versions i have discovered all videos have disappeared from my saved project files
    is this normal?
    ...sometimes u need a PRICK!
    deepvisual
    by deepvisual » Wed Dec 10, 2008 7:53 pm
    keep your M8 file in the same folder as your clips folder.
    that way you can swap computers without having to relocate files.
  • anomad
    by anomad » Thu Dec 11, 2008 5:26 am
    . fantastic ! i can't wait to check it out...
    . are there any plans to send an email to registered users when a new update is released ? i get caught up in other things and sometimes forget to check the forums!
    -james
    (a nomad. )
  • mowgli_uk
    by mowgli_uk » Thu Dec 11, 2008 2:12 pm
    You should always get an email. I know I do!
    by sigmasix » Thu Dec 11, 2008 4:44 pm
    Anomad, you should have recieved an email... Please send us an email to support at garagecube dot com, we will have a look at it as soon as possible.
  • PRICKIMAGE
    by PRICKIMAGE » Fri Dec 26, 2008 9:58 pm
    deepvisual wrote:keep your M8 file in the same folder as your clips folder.
    perfect Mr DeepVisual....all my clips have reappeared....forgot about correct hierarchy when migrating M8 on multiple comp's
    by boris » Sat Jan 03, 2009 8:00 pm
    We send emails to all registered users.
    Check your registration info. :
    [menu Modul8] -> "Update your registrations info"
    anomad wrote:. fantastic ! i can't wait to check it out...
    -james
    (a nomad. )
  • Grovenstien
    by Grovenstien » Tue Apr 14, 2009 4:15 pm
    holy cow,
    I only just saw this! So am i right in thinking .swf multitouch flash apps might work inside M8!? Holy bannanas that would be astounding! I will try this when i get home and report back! although i think that it wont work.
  • Grovenstien
    by Grovenstien » Tue Apr 14, 2009 8:11 pm
    Oh YEAH!
    Multitouch capable .swf files work in Modul8!!!!! This is fing awsome! Wo HOOOO! I will post video as soon as i can!
Users browsing this forum: No registered users and 116 guests
