Luma key for Output window?
  • Evil_Sloth
    by Evil_Sloth » Wed Dec 10, 2008 1:25 pm
    Hey dudes,
    I'm going to be doing some live digital painting in a painting program called alchemy and I was wondering if it is possible to have the output window or the background for modul8 luma keyed or made transparent so I can run visuals over the top of the canvas while im painting.
    Maybe there is a seperate program that can make the modul8 or alchemy application window transparent?
    Cheers.
    Next Gen Visuals.
    deepvisual
    by deepvisual » Wed Dec 10, 2008 7:59 pm
    there are rumours of a quartz composer screen capture patch that will let you pipe one app into another. never used it myself though...
