Photoshop stills are crapping out sometimes
  • technomorph
    by technomorph » Fri Dec 12, 2008 1:57 pm
    Hi Everyone,
    sometimes when I activate some Photoshop clips they just look like a box that is all frapped out. Only thing that seems to get em back is to quit and reopen, not so great in a live situation. Any ideas on how to tweak anything so it doesn't happen?
    the files are too large. All under 1.5mb
    720x480 72dpi
    thanks
    Technomorph
    oh yeah,seem ok on my MBPro but not on the MB
    by vanakaru » Fri Dec 12, 2008 11:40 pm
    I do not use PS files too much. So I have just one mask with transparent backround acting up like graphic card failure (over heating). I let the shop run the test but there is no problem with my MBP. It seems that some times there is a problem with some files.
    Try to remake the clip and see if this solves it (only if this happens to the same clip and randomly.
  • technomorph
    by technomorph » Sat Dec 13, 2008 12:29 am
    Nope it's random clips not one specifically.
  • lamepantallas
    by lamepantallas » Sat Dec 13, 2008 7:02 pm
    Dont use photoshop. Convert them to jpeg or tiff, remember to change the color setting from CMYK to RGB so the color comes out right.
    Good luck!
  • dRead
    by dRead » Sat Dec 13, 2008 11:10 pm
    I find .png files work best, they have an alpha channel and a fairly small filesize. The only time I have problems is when the resolution is really large (over 3000px wide/high) it tends to slow things down a lot. If you don't need an alpha channel, .jpg works great.
    by ilan » Mon Dec 15, 2008 11:23 am
    I use After Effects to create my psd still images. Generates a cleaner alpha channel.
