FULL SCREEN NOT WANTED
  • artoladigital
    by artoladigital » Mon Dec 15, 2008 7:13 am
    I changed a setting and now when I open modul 8 my entire screen is black and I cannot use any of my keys (at all); I have to force quit my laptop to get out of it.
    When I open a project I made in Modul 8 it still fills the whole screen and again all keys are inoperable and I have to force quit.
    I cannot have this.
    How do I change my settings back when I cannot access any of the modul 8 controls???
  • dRead
    by dRead » Mon Dec 15, 2008 7:26 am
    You can try "Command+T", if that doesn't work and you can see the mouse pointer on screen, try clicking on the screen and then retry "Command+T". When you get out of full sceen mode make sure you go to the 'Output" menu and de-select "Full Screen At Startup".
  • artoladigital
    by artoladigital » Mon Dec 15, 2008 7:32 am
    I tried Command T
    does not work
    I cannot see the mouse on the screen no matter what I do
  • artoladigital
    by artoladigital » Mon Dec 15, 2008 7:36 am
    it worked this time...thank you
  • dRead
    by dRead » Mon Dec 15, 2008 7:46 am
    I forgot to mention, if you cannot see the mouse try pressing "Command+Tab" to switch between open applications, the mouse pointer will usually become visible then.
