qt
  • artoladigital
    qt
    by artoladigital » Tue Dec 16, 2008 6:07 am
    can you make qt movies out of what you made in Modul8?
  • mowgli_uk
    by mowgli_uk » Tue Dec 16, 2008 12:10 pm
    yes
  • artoladigital
    by artoladigital » Tue Dec 16, 2008 3:44 pm
    Would you have a link to instructions on that?
  • mowgli_uk
    by mowgli_uk » Tue Dec 16, 2008 4:30 pm
    ...the manual
  • artoladigital
    by artoladigital » Tue Dec 16, 2008 4:36 pm
    I looked in the manual. I could not find it. can you be more helpful? pretend I am a friend who is asking a direct question.
  • renaud
    by renaud » Tue Dec 16, 2008 6:28 pm
    menubar : render => capture to disk
    recordInG and renderInG chapter in the documentation
    reno-
  • artoladigital
    by artoladigital » Wed Dec 17, 2008 4:01 am
    thank you, I have tried this; the manual is not clear on using modul 8 to make qt for use in other programs aside from modul8
    ...only capturing from outsources--not directly making a qt
  • artoladigital
    by artoladigital » Thu Dec 18, 2008 6:01 am
    ok saw how to do this. seemed to work fine except the rendering stops right before it finishes. I tried this with several projects...all under a minute in length. It freezes on a frame and stays there and I need to force quit. any suggestions? I looked through the message board and this seems to be a common issue. I tried several suggestions to no avail.
    Is disk warrior my only solution?
  • Bucharest
    by Bucharest » Thu Dec 18, 2008 9:55 am
    I think it is a limitation of your hardware because if your computer have lower specs on it.... the rendering takes a long time or is freezing.And ... depends what format you chose and what codec you used with how many frames. But to be honest I am trying on my dual G5 with 8 GB Ram and a 10.000 rpm and I am not happy about the results. I tried a lot of codecs and formats and frame rates and it is freezing or I am loosing a lot of frames....so it's maybe a limitation of the software not a really hardware problem,because in my case I can consider that I got some good specs on my computer.For some reason I do not see that many people commenting about this problem ,I asked some questions in the past with no answers about what it is wrong with this picture...and I am still confused not an answer so far that it solved any of the problems that I had in the past....and I still have.
    david
    by david » Thu Dec 18, 2008 4:16 pm
    Hello artoladigital,
    which version of Modul8 are you using ? 2.5.8 ? What is you hardware configuration ?
    Thanks.
    David
