modules dissapeared ..
  • poz
    by poz » Tue Dec 16, 2008 7:04 pm
    It seems that upgrade to 2.5.8 as deleted all my modules ?
    I had plenty of them installed, and no one appears since update ...
    Any solution, without reinstalling them one by one ?
    is it a known issue of 2.5.8 upgrade ?
    By the same time, I changed my monitor config .. i used to have 2 desktop displays (not outputs !), and switched to one desktop screen. All my modules used to be on the second screen. i doubt this could have an effect on the installed modules, but who knows ?
    Thanks much
    Regards,
    poz
  • renaud
    by renaud » Tue Dec 16, 2008 9:20 pm
    You have to back up your modules folder before upgrading 'cause modules are in a sub-folder in your /Applications/Modul8 folder. So if you hav replace your Modul8 folder in Applications, you hav erase all your modules ...
    reno-
  • poz
    by poz » Tue Dec 16, 2008 9:36 pm
    ok, that's exactly what happened
    very good thing to know for the next time !!
    thanks much for the info
    poz
    by sigmasix » Wed Dec 17, 2008 9:57 am
    This has been said in the release note... :roll:
