Module question: Filter; Alpha Blur (Box) - saving settings?
  • Freja
    by Freja » Tue Dec 16, 2008 10:08 pm
    Why does Filter module (alpha blur (box)) saved settings for a specific layer in a project sometimes appear and sometimes not?
    Does the time to time appearance of such a saved setting depend on the usage of computer power at the time?
    g4jon
    Save project
    by g4jon » Wed Dec 17, 2008 12:54 am
    When you save a project M8 should save the specific "state" (all settings as thy are) of the project . If You then modify the settings and do NOT save again M8 will revert to the previous "saved state" the project was in when opened.
  • Freja
    by Freja » Wed Dec 17, 2008 2:07 am
    Yes, I know that but; the settings are saved and still appear different from time to time (opening same M8 project with same saved settings) in this specific parameter..
    g4jon
    by g4jon » Wed Dec 17, 2008 7:44 pm
    Odd, my settings seem to be remembered.
