logical render keeps crashing
  • gcooke
    by gcooke » Sat Dec 20, 2008 12:02 am
    I'm trying to use logical render to render to disk around a 17-minute mix I did. I've tried a number of codecs now, from the default Animation 100% quality one, to DV-Pal, and H.263... the Animation one got around 5 minutes in and crashed, H.263 crashed after 30 seconds, and DV-PAL never even began... I'm only rendering around 4 layers at a time, nothing special, a mix of .avi files and .swf files (all of which PLAY ok).
    Any ideas why I wld hit this issue?
    I'm on a Macbook Pro 2.5ghz with 4gig ram...
    cheers,
    grayson
    by boris » Mon Dec 22, 2008 3:20 am
    Please send your crash report to the support :
    support [a-t] garagecube [d-o-t] com
    That can be located in your system library at the following location:
    [Your user directory]/Library/Logs/CrashReporter/Modul8.crash.log
    Please add theses informations in your message :
    -Your serial number
    -Which version of Modul8 are you using
    -Your system profile (i.e. model, amount of RAM, system version)
    Thank you,
    Boris.
