How to display an error message to the user ?
    aalex
    by aalex » Mon Dec 22, 2008 8:41 pm
    Hi all,
    How can I display an error message to the user from Python ?
    I think the proper way to do it would be to write something in red in the top right corner of the main panel.
    I haven't found any information on how to do this so far.
    Thanks,
    by sigmasix » Wed Dec 24, 2008 11:11 am
    I think in the way you want this is impossible... Currently you can print messages to the Script output (menu Modules > Script > Script Output) using the function print("Hello")
    An other solution would be to add a text caption on your module and change the message in the code using
    Code: Select all
    module.setAttribute ('captionName','CAPTION', 'message')
    zoophar
    by zoophar » Mon Dec 29, 2008 1:18 am
    python allows to use OSA (Open scricting architecture)
    it's also called apple-scritps...
    see something like the module aetools aepack etc...
    import aetools
    print aetools.__doc__
    by sigmasix » Mon Dec 29, 2008 10:19 am
    ahyeah, thanks for the tip!
    zoophar
    by zoophar » Tue Dec 30, 2008 11:41 pm
    we can use it but it's deprecated
    sorry :(
    http://docs.python.org/library/mac.html ... e%20events
    zoophar
    by zoophar » Wed Dec 31, 2008 2:36 pm
    So i've been looking forward to display en error merrage
    without adding any libs or modules to python.
    i made some cow fu fighting and some googling on the web...
    i've found
    http://www.doughellmann.com/PyMOTW/Easy ... index.html
    wich seem to be very simple... and user friendly
    Code: Select all
    import EasyDialogs
    print EasyDialog.__doc__
    prints the doc about it and all the dialog box we can use...
    So, i've tested in the terminal with the first example on the page
    Code: Select all
    import EasyDialogs
    EasyDialogs.Message('This is a Message dialog')
    the appliction launcher started and it displayed the message 'this is a Message dialog' with an OK button...
    then, i started M8 and copy pasted the code in a new module and started the module.
    M8 freezed...
    does anyone know a bit more about this?
    Cheerz and happy new year!!!!!
    by sigmasix » Wed Dec 31, 2008 2:47 pm
    Hi, thanks for the tip!
    I tried on the terminal, I discovered the python rocket, it's fun, too bad the massage doesn't come up in front...
    I also tried in modul8, and like you I had the doom beachball... But also had the message... But no way to click ok... We'll see what we can do about it, either this working, or a 100% modul8 solution
