[Audiovisual] Monomal Demo + Guide
    Anome
    by Anome » Tue Dec 30, 2008 2:25 pm
    http://vimeo.com/2668433
    "Monomal" is a special module for the 40h monome.
    It allows the user to control the video layers of Modul8, the opacity, the speed, the timeline, in a very fluid fashion.
    SEE MORE AT www.iduun.com
    Image . . . . Image
    Anome
    by Anome » Tue Dec 30, 2008 11:41 pm
    If you don't have any monome, you can use the 'Virtual Monome' module (downloadable from the online library of modul8) ...
    Image . . . . Image
  • anomad
    by anomad » Fri Mar 27, 2009 8:33 am
    . that is absolutely amazing! :D
    . thank you for sharing! now, to find a monome somewhere..
  • meiso
    by meiso » Fri Mar 27, 2009 5:21 pm
    Very cool!
    Anome
    by Anome » Fri Mar 27, 2009 5:24 pm
    thanx :)
    dont hesitate to ask us ---> contact@iduun.com
    see ya !
    Image . . . . Image
  • annapurna
    Monomal praise and suggestions
    by annapurna » Wed Aug 12, 2009 8:09 pm
    Just wanted to let you know that both the monomal and virtual monome modules have become a huge staple of my live performance. they really are powerful. After using it for some time, I've come up with a few suggestions...
    It would be great to see a future version of monomal in which the user can modify the lower-half controls, simply because i have other controllers capable of handling the speed and opacity, and would like to have as much control as possible. i could even see potential in using the bottom half as a bunch of mappable on/off switches.
    Also, the modul8 function for recording a layer and playing it back looped, as well as the function to record the master layer and rendering it to disk later, both are unable to record the "scratching" done with the monomal module. It seems complicated to fix, but if you did, it would add an extreme amount of usefulness to the module: being able to play back a looped sequence of button-presses would be amazing.
    thanks again for these modules. i really wouldn't be able to perform in the way that i want without them.
    Anome
    by Anome » Wed Aug 12, 2009 8:24 pm
    Well, i m working (at this precise time) on the second version of Monomal.
    I think, you ll like it. List of features (some inspired by DJ64) :
    - pagination system
    - working with 6 layers
    - BPM tap and beat synchronization
    - overriding audio management to accurately change : the pitch, the speed (without the pitch), repeat effect, better scratch effect, ...
    - record function
    The pagination system should be great to add pages which fit your needs.
    The record function should be able to replay accurately what you did.
    Image . . . . Image
  • annapurna
    re: 2nd version of monomal
    by annapurna » Wed Aug 12, 2009 10:35 pm
    that sounds perfect. eagerly awaiting its completion.
  • workhouse
    monomal fader question
    by workhouse » Thu Nov 05, 2009 8:41 pm
    hi
    can you tell me how to alter the speed of the cross fader
    in monomal
    it is just jumping across and i need it to be slower
    loving your app perfect !
    Anome
    by Anome » Fri Nov 06, 2009 3:28 pm
    This feature doesnt exist. You can ask for it, by entering a feature request in UserVoice (a website which collect customer feedback) :
    - go to Monomal
    - choose the "about" tab
    - click on the "give feedback" button
    Or use this link : http://monomal.uservoice.com
    Dont hesitate to vote for other features !
    Bye,
    Philippe
    Image . . . . Image
