BACF adaptation.
  • stuart
    BACF adaptation.
    by stuart » Fri Jun 17, 2005 1:34 am
    I would love to take the functionality of the BACF tapper and be able to route it to other parameters. Specifically individual layer opactiy. I imagine an interface like you already have but with 10 radio buttons on the right that allow me to select which layer to route the value to. Would this be hard to do? I have looked at the keywords and I see one for layer opacity but I don't seem to grasp the syntax for picking something other than the active layer.
    many thanks
    by sigmasix » Fri Jun 17, 2005 8:59 am
    there are two modules in the online library, one called BPM and the other Random Frame.
    synchronise some features of modul8 with the rythm, you can check the source of this one to do what you want. Random frame has the 10 radio buttons, so also check the source code to use it in your own module 8)
