Layer modes like add or multiply
  • dexterartics
    by dexterartics » Sat Jan 31, 2009 2:56 am
    hey,
    iam enjoing the modul8 demo and i already
    watched the tutorial on the site. but i cant find
    simple solutions to do a simple multiply mode effect like in photoshop or after effects...
    is there anything without having clips with alpha channel?
    and if not, what is the best way to bring alpha from after effects to
    modulate?
    thanks ronny!
    wygiwys
    by wygiwys » Sat Jan 31, 2009 10:38 am
    Use the luma effect?
    When you're on the layer, it's next to the blur effect (I think)
    But I always use that one. It does take a lot of cpu i heard.
    What You Get Is What You See
    WYGIWYS.tv
    deepvisual
    Re: Layer modes like add or multiply
    by deepvisual » Sat Jan 31, 2009 11:29 am
    dexterartics wrote:i cant find
    modulate?
    you wont find blend modes in M8 - not yet anyway.
    as for alpha channels.
    http://www.youtube.com/watch?v=FGNJ7XEG-Ss
    I'd suggest using PNG+ codec
    by vanakaru » Sat Jan 31, 2009 11:39 am
    the luma key effect makes blacks transparent so the layer under it will show through. it will not be the same as blending mode>multiply but similar. you can choose to key out R or G or B separately as well. to my it has more flexibilities that simple blend in AE.
    with alpha you deal with huge file sizes. its animation codec or png that supports alpha.
  • dexterartics
    by dexterartics » Sat Jan 31, 2009 2:38 pm
    thanks for that much anwers, now i will experiment with ur hints.
    have a nice weeekend!
  • snt
    by snt » Tue Apr 14, 2009 10:25 am
    In another thread ( http://www.garagecube.com/forum/viewtopic.php?t=618&highlight=multiply ) it read that the blending modes (Screen, Multiply, etc.) would be introduced in version 3. Any word on version 3's release schedule? 2009? 2010? 2011?
    The blending modes would be the coolest thing to have. Luma key or alpha channels are just not the same thing.
    by ilan » Tue Apr 14, 2009 12:45 pm
    Blending modes will be before v3. For v3 I am not allowed to provide any information for the moment.
  • snt
    by snt » Tue Apr 14, 2009 4:22 pm
    Great news!
  • nikon
    by nikon » Tue Apr 14, 2009 6:47 pm
    ilan wrote:Blending modes will be before v3. For v3 I am not allowed to provide any information for the moment.
    2.6 ? :) i realy miss blending modes from other soft when i swiched to module8 ive learned to live without them but if you can add them before v3 thats a great news!
