X Y Z unwanted triggering with audio
  • lamepantallas
    by lamepantallas » Mon Feb 02, 2009 5:11 pm
    Hello M8users,
    I just had a gig this past weekend and x y z controls moved o triggered to certain position without being moved by me. I guess it was the music. The other thing that seemed strange was-following the above-, for example, that the transaparency didnt go all the way to the right, aswell as the fader to either side. I turned off the audio input on the computer aswell as the knob in M8, yet the problem persisted.
    Some insight? Thank you.
    g.
  • mowgli_uk
    by mowgli_uk » Tue Feb 03, 2009 12:39 pm
    This sounds like you've either got a module doing this or you've recorded it and its playing back. Another cause could be your midi mapping.
  • lamepantallas
    by lamepantallas » Tue Feb 03, 2009 7:33 pm
    Nop, no recording. Midi mapping, how?
  • mowgli_uk
    by mowgli_uk » Tue Feb 03, 2009 8:53 pm
    If you've been using layer set and position midi mapping you can map more than one interface item to a single controller, so maybe by accident or forgetting what you've already mapped you are causing the random changes while controlling something else.
    have you checked your modules, specially the BPM layer?
  • lamepantallas
    by lamepantallas » Thu Feb 05, 2009 4:58 pm
    Thanks for the insight!
  • lamepantallas
    by lamepantallas » Wed Feb 25, 2009 7:19 am
    still the same problem, no audio in, bpm deactivated...
    the layer transparency does not go all the way to the right....
    anyone?
    im using UC33-E
    i have reset it, yet it persists,... =(
  • vj_ava
    by vj_ava » Wed Feb 25, 2009 8:35 am
    make sure the UC33 is set correct. sometimes instead of 0-127 the midi's internal settings can get changed on accident. that means instead of 0-127 you might be getting 0-80. therefore missing 47 increments.
  • lamepantallas
    by lamepantallas » Thu Feb 26, 2009 3:01 pm
    will do, thanks for the support!
