use movie as alpha layer
  • wickedmartin
    by wickedmartin » Sat Feb 07, 2009 1:24 pm
    hi,
    i am very new to modul8 and playin around with the demo.
    is it somehow possible to use a black/white video clip as a layer mask or alpha for another layer?
    kinda like the "alpha lines" filter in the "filter (layer)"-modul, but not just with lines but with a movieclip.
    check out my illustration, i'd like to be able to change layer1 and layer2 on the fly with the mask-movie always applied. is that possible?
    thanks for the info,
    martin
  • wickedmartin
    by wickedmartin » Wed Feb 18, 2009 12:47 am
    any idea anyone?
    Vincent-Pimousse
    by Vincent-Pimousse » Wed Feb 18, 2009 2:27 am
    I think it is not yet possible but it could be made with a freeframe effect for basic shapes.
  • bratch
    by bratch » Wed Feb 18, 2009 3:53 pm
    yes, this would be great !
  • Vibber
    by Vibber » Wed Feb 25, 2009 1:33 pm
    It is definitely possible to make as a Quartz composer file.
    But then you would have to specify the media in the Quartz file itself.
    It would be nice to have in modul8 as a filter so you can select your movie and mask movie on the fly.
  • vj_ava
    by vj_ava » Sat Feb 28, 2009 8:15 am
    If there was a layer mask instead of global mask that might work pretty good.
