MIDI note off
  • fons
    MIDI note off
    by fons » Wed Jul 21, 2004 2:49 pm
    hi all,
    when assigning MIDI notes to the clip grid, i get the clips triggered with note on and when releasing the key, the clip is triggered a 2nd time (starting again) - annoying. is this normal behaviour? how can i bypass this problem? don't think i can strip note off in my hardware keyboard settings ...
    thanks
    fons
    yves@garagecube
    Re: MIDI note off
    by yves@garagecube » Fri Jul 23, 2004 5:51 pm
    fons wrote:hi all,
    fons
    Yes... We know this problem. Will be fixed in a next minor release.
    Yves.
  • fons
    by fons » Fri Jul 23, 2004 6:12 pm
    Hi Yves,
    thanks a lot - glad to hear you'll fix that even before the next major release :)
    Fons
    by boris » Fri Jul 30, 2004 10:56 pm
    OK !
    Is now fixed with the new 1.0.2 version.
  • Guest
    by Guest » Sat Jul 31, 2004 10:44 am
    great, thanks for fixing this problem within a week! makes thinks much smoother. really appreciate your work :)
