Two Monitors for one mac Pro
  • JulieS
    by JulieS » Sun Feb 22, 2009 5:39 pm
    Hi!
    I'm sorry I sure that topic must have been traited but I couln'd find the threal. Here is my question;
    How can I plug two Video Projector with modul 8 to my Mac Book pro (only one VGA out put).
    Thanks for your answers!
    by sigmasix » Sun Feb 22, 2009 5:51 pm
    answer: matrox dualhead2go
    there's also a word about it in the documentation.
    If you want the same image on the two beamers, a splitter would do the trick.
    deepvisual
    by deepvisual » Sun Feb 22, 2009 7:55 pm
    some projectors have a VGA out/through
    this lets you daisy chain projectors.
  • mowgli_uk
    by mowgli_uk » Mon Mar 02, 2009 6:30 pm
    If you use the DVI-composite adapter and you don't want different outputs you can use the s-video and composite outputs on the adapter at the same time.
  • starsk
    Some freeframe bug and one effect to main output
    by starsk » Sat Mar 07, 2009 2:48 pm
    Hello
    I'm sorry if that question was already asked...
    I would like to use the Freeframe plugin ColorWrap, to do a color cycle effect.
    I installed the freeframe effect in Modul8 plugin folder.
    Most of my freeframe effects works, but some don't, like ColorWrap, TVPixel, Meta Image ...
    When i apply them to a layer, this one diseaper, and you can see the bottom layer image.
    Any idear ?
    Also, i would like to know if there is a way to apply an effect to the main output of Modul 88 ?
    How to apply the same effect to all my mix ? Is there a way other than select my layers one by one and apply them the effect ?
    Thanks
  • starsk
    by starsk » Sat Mar 07, 2009 2:49 pm
    Oups, sorry, wrong place ...
