render tricks
  • mattblack
    render tricks
    by mattblack » Thu Feb 26, 2009 7:28 pm
    hi
    say i am using hidef clips with effects, and the output is at a very slow frame rate coz the effects are slowing it down. can i tell modul8 to process at a lower output resolution so it is faster, do a logical record, then render that logical record at a higher resolution to get full resolution/quality at full frame rate?
    Can modul8 be used like this? it would make it more suitable as a production tool.
    thanks
    by vanakaru » Thu Feb 26, 2009 11:41 pm
    I don't think so. Logical record is very slow and CPU hungry by itself and will most likely crash your project. Just get faster machine like MacPro and use record>capture to disk.
  • incuf
    by incuf » Fri Apr 24, 2009 5:13 am
    What you CAN do.. Is render a logical record with clips playing and Fx's on, it will render slow but I think that won't skip frames. So wgen you import that rendered clip it will play smooth.
    Give it a try.
    IncuF
  • vjspetto
    by vjspetto » Wed Jun 10, 2009 7:00 pm
    Just do your perfomance using the Logical Recorder. After that render it using a good file codec (I always use Apple Intermediate or PhotoJPG). Voilá! Your video will be with a very good frame rate, without skipping anything.
Users browsing this forum: No registered users and 63 guests
