layer parameters not saved
  • mowgli_uk
    by mowgli_uk » Mon Mar 02, 2009 2:10 pm
    I'm having issues with layers that are distorted using either the perspective transform FF or the XYZ layer controls. Basically their positions are not saved with the project and when re-opened the layers always appear centered. This is a mayor issue for mapping projects as every layer needs to be repositioned every time.
    Is there a solution/workaround for this?
    Also when duplicating a layer some of the FF parameters are not duplicated.
    Cheers.
