Layer Auto Select
  • starsk
    Layer Auto Select
    by starsk » Fri Mar 06, 2009 6:42 pm
    Hello
    I am a new user of Modul 8, thanks for this great software.
    I am using Modul 8 with a UC-33 controller.
    I would like to know if there is a way to autoselect a layer when i activate it with the controller ? So i don't have to select it with the mouse... :)
    Thanks
  • mowgli_uk
    by mowgli_uk » Fri Mar 06, 2009 6:54 pm
    in layer set midi mapping mode map the controller that you're using to activate the layer to the layer select bit of interface too. That's it.
    by vanakaru » Fri Mar 06, 2009 9:02 pm
    at the very top bar next to modul8-v2.5 is a tab layerset+position. when this tab is selected you can map all 10 layers to midi.
  • starsk
    by starsk » Sat Mar 07, 2009 12:37 pm
    I get it, thanks :)
