Locked 8 posts Page 1 of 1
export resolutions and quality
  • five
    by five » Mon Jun 20, 2005 6:26 pm
    hy maybe someone can help me. i try to get something exported wich i did in dv-pal 720-576 25ps. what is the best quality to export after i scrached something and recorded it to the disc. i would like to work with it in final cut hd. so what is the best quality? thanks for any suggestions,
    five
    by sigmasix » Mon Jun 20, 2005 6:41 pm
    hey, what's happend to this forum?!?! is it fashion to post twice the same message?! it's a bit stupid because you will not have more answer and the answers will be splitted in two different posts and everybody will be confuse :roll:
  • five
    shit youre right
    by five » Mon Jun 20, 2005 6:51 pm
    i was just gessing that nowbody would read this relpy so i started a new topic. it just because i really need help on this one. sorry.
    Re: export resolutions and quality
    by boris » Mon Jun 20, 2005 8:17 pm
    five wrote:hy maybe someone can help me. i try to get something exported wich i did in dv-pal 720-576 25ps. what is the best quality to export after i scrached something and recorded it to the disc. i would like to work with it in final cut hd. so what is the best quality? thanks for any suggestions,
    five
    Do you use the hd resolution or dv resolution in final cut ?
  • five
    by five » Mon Jun 20, 2005 8:31 pm
    i use the dv reolution.
    by boris » Mon Jun 20, 2005 9:53 pm
    five wrote:i use the dv reolution.
    Try : 768 x 576 (PAL square pixel)
  • five
    this works
    by five » Tue Jun 21, 2005 10:20 am
    thanks so far. it seams that the actual quality is ok but still it seams that it drops frames. is this possible or does it just apear that way? even wenn every other program is closed. in fc it alway apears to have less frames, meaning it studeres. is there a way to get around that with a less high resolution video souce (like this .jpg compression you recomand) or is it just a fact that wount go away. is there some kind of trick i could use to start with a very good quality and end up in good quality?
    thanks for you help, five
    Re: shit youre right
    by boris » Tue Jun 21, 2005 1:18 pm
    five wrote:i was just gessing that nowbody would read this relpy so i started a new topic. it just because i really need help on this one. sorry.
    You need to be PATIENT please.
    This tread is closed now.
