Runtime error in "(vs) Synchro (layer)" (Listen) a
  • FAiLUr3
    by FAiLUr3 » Mon Mar 09, 2009 3:17 pm
    Everytime when i launch Modul8 it will appear error message :
    Runtime error in "(vs) Synchro (layer)" (Listen) at line 8
    IndexError: list assignment index out of range
    when i click on "Go to Error" it will open new window with this
    if msg == 'ctrl_position':
    ctrl_position = param['value']
    if ctrl_livesynchro:
    resynch(ctrl_position)
    elif msg == 'ctrl_selectLayer':
    target_layer=int(param['NAME'])
    layerStack[target_layer]= int(param['value'])
    elif msg == 'ctrl_synchro':
    elif msg == 'ctrl_livesynchro':
    ctrl_livesynchro = param['value']
    the line 8 is layerStack[target_layer]= int(param['value'])
    at all layers is loaded same video :( ...
    can anybody help me pls ? thx
  • mowgli_uk
    by mowgli_uk » Thu Mar 12, 2009 5:45 pm
    as i mentioned on your other post, the culprit is the synchro layer module. just switch it off or delete it from your modules folder before opening your project
